Python Node not working on EXE file (works on development computer)
Hello!
I have a VI that uses multiple python nodes. Works without issues. When I create an executable for distribution (and installer, including Python and the .py files), the exe does not run the python nodes. I have included a simple sample vi, and the exe (the installer with python is too large to upload, so if you are going to test it, you need python and the path for python set in the environment). Also added some images of the exe and installer creation. Notice that I placed the .py file in the folder that I am calling in the vi blockdiagram.
I am at a lost. Any suggestions?
(2,017 Views)
Accepted by topic author jlp324-sirona
figured it out!!! The folder is actually under c:\Program Files\check\ not c:\check... must pay attention to the path in the python node.
(2,014 Views)
Thanks for sharing your solution and marking it as such.  This will help others in the future.  🙂
Bill
CLD
(Mid-Level minion.)
(1,964 Views)
