Puzzling Error 3005 Question
I have LABVIEW 2010.  And I have a code 3005 error after creating a Automationrefnum.  My Automationrefnum sees the properties and methods of the class I am using.  I successfully registered my .TLB file.  I know this because I used the ccrpREGUtil tool I downloaded from the NI Website, and it says it registered the TLB successfully.
I have my Autorefnum attached to an Automation Open vi, and after that I have property nodes and invoke nodes.  I can select my properties and methods of the class I am using in these property nodes as well, but unable to get rid of this error when I run this VI.  When I right click the Automationrefnum and select ActiveX class and check "Show Creatable Objects Only" box, I can select the class I need, so it is creatable.
There is one more hint to the puzzle.  A friend of mine is running the exact same code with the exact same tlb file and he does not get this error.  What could it possibly be?
Danny
(2,328 Views)
(2,323 Views)
