I want to put a shortcut to my LV executable into the All Users Startup folder so that anytime a user logs in, the application will start up. I know this can be done manually very easily, but I would like this to happen automatically as part of the installation. I tried creating the shortcut and adding it as a support file, but this has the problem that once you select the shortcut to add, you get the target added to your list instead of the shortcut. I worked around this by putting the shortcut inside a folder and adding the folder contents. When I installed the app, the shortcut was placed in the right location but was corrupted.
The logical use for choosing the Destination Setting to be "Startup Di
rectory" is for this very purpose. It seems like it should be straightforward...
It also noticed that you cannot play the game of renaming the file with a different extension such as TXT - Windows still knows it is a shortcut. Any ideas?
