Put breakpoint programmatically
Hello folk,
Is there any way to put breakpoint programmatically or puase VI on certain occasion?
CLAD
Passionate for LabVIEW
(5,406 Views)
Accepted by topic author jatinpatel1489@gmail.com
You are most probably looking for a conditional probe: Right-click on a wire > Custom probe > ...
In Help sreach for "probes" and then select the "creating custom".
Happy VI-ing!
(5,395 Views)
jatinpatel1489@gmail.com wrote:
Hello folk,
No! But you can suspend a callee VI programatically. Run the attached VIs & see.
- Partha ( CLD until Oct 2027 🙂 )
(5,374 Views)
Happy to help you! Thank you for accepting a solution and giving KUDOs!
(5,343 Views)
Just a note to anyone who is trying to do this programmatically:
Traverse the block diagram via scripting for the SubVI node you're interesting in attaching a breakpoint to.
Then write to its "Breakpoint Status" property.
I can also confirm that this can be done while the VI is running, and that the property exists on many, if not all, block diagram nodes.
Mr. Jim
(2,781 Views)
This should be a Method, actually!
Set BP
Enable BP
Disable BP
Clear BP
(2,515 Views)
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(2,509 Views)
