Put Data in a 2D Array after Button pressed
hello. following question:
I have a cluster, where I can put various data input as parameter for a test stand. After all data is inserted the user should press an OK button. The data should now be inserted in a 2D array in the first line. After the user has filled in the next data in the cluster and press OK, the next line should be filled in. This must happen 10 times. But a chance to leave this loop should be given.
Can anybody help me here? thanks a lot
(3,018 Views)
Try this as a basic structure...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,018 Views)
Thanks Mike
That helped me a lot. But I have one more question. Does your example also work with different types of input data e.g. boolean, integer, text???
Greetings
(3,018 Views)
As long as you are consistent about datatypes, it should work fine with any sort of array data. 1D array of clusters, 2D array of any datatype. It will all work basically the same.
What exactly do you need the data input to look like?
Mike...
LabVIEW Champion
(3,018 Views)
Here I've the frontpanel for my data input. I hope that's it, what you asked for. This line in the Frontpanel should be parsed while the input process and give popups for information if the user made a wrong input. afer press the button right under the cluster, the data should be written into the array line. by the next button action the nex line and so on.
Thanks for your reply!!!
PS I'm just a beginner in graphical programming 😞
(3,018 Views)
Sorry I forgot something: the data that should be stored in the array has to be transferred all into string, after checking all conditions, because the data should be saved in on ini-file.
(3,018 Views)
