PushOk Visual Diff
I have a question about the visual diff function in LV 8 Source Control using the PushOk Client
It seems like there should be a way to tap into the built in vi compare utility ... but I am not sure how to do this.
Has anyone tried to figure this out?  I tried to use labview.exe as the external program for the diff,
but this seems to be crashing things.
Thanks!
Leo
(2,984 Views)
You may have to do use the graphical differencing tool directly from LabVIEW, rather than launching it from your SCC client. You should note that the diff tool has only been tested and is only officially supported with Perforce and SourceSafe. You might check here for more information on LabVIEW and the diff tool in particular. Hope this helps!
Jarrod S.
(2,957 Views)
Thanks for the help.
(2,950 Views)
