Pulse generation using PCI-DIO-32HS
    I want to generate continous pulses with defined duration of On time and OFF time. How i can do this can any one send a simple example on this.
(2,694 Views)
Probably the easiest way would be use the example for generating a continuous pulse train in the LabVIEW examples and calculate the freq and duty cycles from your on/off times.
Doug
Doug Asselbergs
Certified LabVIEW Developer
(2,678 Views)
