Pulse Train with DAQ700
I want to create a finite pulse train with a DAQ700-card. (I think the examples
in LabView don't work with the 8254 counter that comes with the DAQ700). How
can I create a pulse train and on what pin of the connector can I find (and
use) it?
Regards
Martin
Posted via Mailgate.ORG Server - http://www.Mailgate.ORG
(2,666 Views)
Martin,
Since the 8253 and the 8254 chips are very similar, you can visit ni.com and make a search on "8253". Some of the results that you will get from the search will be example programs that show how to do Pulse Train Generation in LabView, LabWindows/CVI, etc.
Each example program will also have information on how to connect your I/O signals to the hardware.
Good luck with your application!
(2,666 Views)
