10-22-2010 04:59 AM
I'm trying to measure the pulse coming out of my flow meter and I contacted the manufacturer for some help. They provided me with the attached example that counts the pulse. I know how to calculate the volume given the pulses, what I'm having trouble with is figuring out how to adjust the time on the code, This is the formula that I'm trying to use for the flow rate Q= Volume / Time (t2-t1)...but I want to set it such that I could adjust it if I needed to. I'm also attaching the VI manual that essentially explains what each VI does just incase..
10-23-2010 02:54 PM - edited 10-23-2010 02:56 PM
oops
10-23-2010
02:55 PM
- last edited on
07-08-2024
01:41 PM
by
Content Cleaner
in attachement an example of code using state machine / passing state in shift register
use of a cluster also passed in shift register that contain local variables
you can also look a state machine example in tutos
Hoping i undertood your question if not
your welcome for more details you can also give more precision on about what you want to do
Regards
Tinnitus
