Protection of source distribution
I have created an application with plugin architecture (Labview classes). When I distribute these plugins all VI are unprotected. I know that I can password protect VIs, but is this save way for protecting against stealing source code?
What are other options for protection? Something like DLL would be great, but I can not use it because plugins have user interfaces.
Can removal of front panel and block diagram be of any help here?
Thanks!
(3,544 Views)
This question has been asked before numerous times, with various suggestions given. Have you tried a search? Certainly stripping the block diagram is a viable option. NI also provide a licensing toolkit which may work for you. Please search the forum and see what's already been suggested. If you want to discuss the pros and cons of a specific approach, post back.
(3,538 Views)
And exactly why do you think you cannot create a dll? Your statement about front panels seems to indicate that you think a dll cannot have a front panel. That is, of course, wrong.
(3,530 Views)
Dennis, yes I was wrong about dll having front panel.
(3,504 Views)
Personally, I think removing the block diagram is wrong since it prevents the user from user the VIs with a newer version of LabVIEW. Whether you password protect the VIs or remove the block diagram, that still would not prevent someone from calling the VIs from a different VI. If you feel like you really need to do this, you would need the licensing toolkit.
I'm not at all sure why it would be such a big deal if someone were to use a VI that they have purchased in any way they saw fit.
(3,493 Views)
andrej wrote:
Well, if you strip out the block diagram they certainly can't copy the code. As for using them for their own purpose, you'll need to be a bit more specific as to what you mean by that. If the VIs have adequate documentation as to what they do, and/or their use is obvious, there's nothing that would stop someone from using that VI for something else (even with the block diagram stripped out).
(3,482 Views)
The only idea I can come up with to limit the scope of use of any vi you supply would be to add an authentication key (case structure) around every vi probably tied to a functional global writen only by the "owning ancestor" then rip out the BD's.
Of coares, I might not buy a program from you again if you took the time to do all that. Smiley Mad
"Should be" isn't "Is" -Jay
(3,477 Views)
