Property nodes and event structures
Is there any way to get an event structure to react to the change in state of a property node?
I have a property node 'Cursor.Cursor Position.Cursor X' for a waveform graph and I'd like to execute an event case when its value changes.
I am having real trouble getting this to work and any help would be much appreciated.
Many Thanks,
Stuart
(3,019 Views)
The only one I know of is the property Value (Signaling).
However, there may be some creative ways to create some other trigger.
Are you programmatically monitoring the cursor position?
R
(3,011 Views)
Create an event for cursor move. 😄
Use a shift register to see which location has changed and add a case so the impartant code only executes if X differs.
(This is not available for very old LabVIEW versions. If you don't have it, you need to poll.)
Message Edited by altenbach on 07-04-2008 09:49 AM
(2,985 Views)
Thanks Altenbach..
I learn something new everyday on this forum. 🙂
I would never have thought to look for Waveform: Cursor Move..
(2,970 Views)
Many thanks for your help.
The problem is now solved.
Stuart
(2,917 Views)
