Property node
Can we use property node to pass data between two VI's?
(2,800 Views)
Yes.
(But there are better ways...)
(2,779 Views)
Instead of using property node directly you can use direct wire terminal (through VI connector pane terminals).
Save your VI memory usage!
(2,772 Views)
