Property node for 'source' of Error Cluster gives some problem for PDA
    When a property node for the 'source' string of Error Cluster is used with LabVIEW PDA, there is sometimes build error. As shown in the attached VI, this property node for the 'source' string is used to update the 'source' boxes of 'Fatal Error' & 'Fatal Error Out' nodes. Can anyone suggest an alternate approach to achieve the same goal on PDA?
Thanks & Regards,
Subhashini
(6,947 Views)
Hi Subhashini
why don´t you use "bundle by name" and write the result to error output?
Mike
(6,943 Views)
Hello Mike,
    Thanks again! I notice that there's one difference between using the property node & ur suggestion - The 'source' box of the 'Fatal Error' node does not get updated with the 'Value' string...
Thanks & Regards,
Subhashini
(6,924 Views)
Hi Subhashini
your are right. I know the diffence, but is it necessary that the input will be updated?
Mike
Message Edited by MikeS81 on 02-12-2008 06:19 AM
(6,918 Views)
Hello Mike,
    I guess it may be necessary...In any case, thanks...Now i can atleast go ahead with ur suggestion.
Thanks & Regards,
Subhashini
(6,912 Views)
