Property Node (arg 1) in VISA Configure Serial Port (Instr).vi
Good Morning,
I'm Davide Masi, I'm a problem on the VISA: Property Node (arg 1) in VISA Configure Serial Port (Instr).vi
1. what is arg 1?
2. Is possible reset the serial port with RESET BUSS OFF or an another hard RESET?
Best Regards
Davide
(3,658 Views)
Where are you getting that error? Usually that's due to trying to set a VISA parameter that's not supported by the hardware. Are you using some sort of serial converter box? What kind? What does your code look like?
Also, what do you mean by "resetting the serial port"? Are you referring to flushing the TX/RX buffer?
(3,650 Views)
