Property Node OR Local Variable ??
Hello !
I am using a cluster (3 Values) in an event ... and I want to change its
values (2 of them).
I am wondering which is the better nicer solution for this .. two property
nodes with values or a going to a Local Vaiable by building the cluster new
Thans for your tips
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
(3,865 Views)
It all depends on what you need. If all you want to do is update the value then the local variable is the most straight forward and most efficient. If however, you want to trigger an event on one of the value changes you'll have to use a property node.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,865 Views)
Hello
One more question.
According to Mikes post, I assume that an event is fired on write value to
a property node (in an event).
But the "change value" event does not trigger these events ?
How can I fetch this event ?
Tanks Sascha
> Mike...
(3,865 Views)
There's a property "value" that won't trigger a change event, and one called "value (signalling)" that does trigger a change event.
Mike...
LabVIEW Champion
(3,865 Views)
