Properties and Array inside Cluster
I have a complex structure of LV controls defined as a strict typedef: Array
of cluster with a number of controls inside. One of the controls inside the
cluster is a array.
On the frontpanel I display this control and I will programmatically set the
index of the array inside the cluster.
Is it possible??? How??
Hans ?hra
(3,109 Views)
This does not appear to be possible with a strict type def control. I would suggest finding a slightly less complex method of displaying your data.
Brian
(3,109 Views)
"I have attached an example that illustrates how to accomplish what you are trying to do. One of the key elements in getting it to work is the use of the "To More Specific Class" function.
There is some good related information available at:
http://digital.ni.com/public.nsf/ 3efedde4322fef19862567740067f3cc/ b4f437c8bf034293862569f800618197?OpenDoc ument
Please let me know if you have any questions.
Thanks.
Matt Kisler
Application Engineer
http://www.ni.com/ask"
(3,109 Views)
They stated in their question that they are using a strict type def control and this won't work with one. I tried the same exact approach.
Brian
(3,109 Views)
