Proper Resolve Machine Alias Usage
I am writing a VI to retrieve the physical network address from the local machine running the VI.
I was told to use the Resolve Machine Alias.vi.
However, I receive input parameter errors when I run the VI.
I do not see any examples in the example finder and I am not sure how to resolve the error.
I am using the Open Application Reference VI to obtain a reference to pass to the Resolve Machine Alias VI.
I am able to get a list of addresses by using a property node on the Open Application Reference VI however,
this seems clugy and does not provide me with a means of finding link speed and duplex.
Any Advice?
Should I be using a different method all together?
Thank You,
forrestjon
(4,061 Views)
Hi forrestjon,
i don´t know the Resolve Machine Alias.vi, but if you mean the MAC adress and other information you can use the SystemExec.vi and parse the result.
Hope it helps.
Mike
(4,059 Views)
Hi forrestjon,
Is this what you are looking for?
oops, attached the wrong pic the first time Smiley Very Happy
Message Edited by lmtis on 06-10-2008 02:47 PM
Message Edited by lmtis on 06-10-2008 02:48 PM
Jim
LV 2020
(4,051 Views)
Hi Mike,
Thank you for your suggestion.
I tried using the system exec.VI and noticed it does contain the IP address.
However, the duplex mode and link speed are not present in the cmd /c "ipconfig /all" output.
Is there a way to obtain these parameters?
Also, I would like to make my VI OS independant.
I am able to obtain the IP Address using the Open Reference VI and parsing the TCPAccess property for the first array element.
I think this method will work on my MAC OSX machine as well.
Thank You,
forrestjon
(4,041 Views)
Hi Jim,
Thanks for your response.
Actually I am lookig for a way to access the network properties of the local computer.
I wat to read the IP address, Duplex Mode, and connection speed.
I tried using the VI you posted to strip off the IP Address from the TCPAccess property and it returned
all 0's seperated by dots.
I believe this is due to the "+" symbol proceeding the IP address in the IP Address string.
Do you know of a method for obtaining the IP Address, Duplex Mode, and connection Speed?
Thank You,
forrestjon
(4,025 Views)
