Prompt for overwriting a file in "Write to Spreadsheet File" vi
Problem:
I am sending a 1-D array to "Write to Spreadsheet File", which opens a dialog box to where I save the data. I understand that I can overwrite or append a file. However, when set on overwrite, I would like a prompt that says "Are you sure you want to overwrite this file?" So I accidentally don't overwrite some data I need. Is there a way to do this within "Write to Spreadsheet File"?
Thanks!
(4,594 Views)
No.
What you need to do is put your own File Open dialog ahead of  the Write to Spreadsheet File.  Once a file is picked, check to see if the file exists.  If it is, then you ask the question in a dialog box.  Put the Write to Spreadsheet file in a case structure so that it only executes if the person answered OK.
The File Dialog Express VI in the File I/O >> Advanced palette can help you here.  It has an Exists? output.
(4,589 Views)
