Prompt User for Input - Limit String Length
I am currently using the "Prompt User for Input" function to allow the user to define the path to save the file.  In order to control the length of the file name, I want to be able to put a limit on the amount of charcters the user can input when the Prompt is shown.  Is there an easy way to do this?
(3,957 Views)
You have to spin your own dialog. You can convert that Express VI into a regular VI by right-clicking and select "Open Front Panel" (or something like that). It will give you a dialog and you can then save it as a regular VI. You can then modify it to limit the string length.
P.S. This question has come up several times before.
(3,942 Views)
