Project management + Source Control
we are using labview 8.5 and not well known source control in a team environment. I'm not sure if it is the souce control that I'm using or other searsons, but I had so much trouble using those combination. I want to know what others thought about project management and/or source control in general.
 - Jimmy
- Jimmy
(3,728 Views)
Hi!
   In my opinion, Source control is mandatory, also if you work alone (at least for versioning code....).  If you work in a team, you have to take great care in merging code produced by other people, and you'll probably need some times to get used to.
   About LV 8.5, I have to say that I use LV 7.1 and an extern tool (tortoise + SVN), i.e. not integrated in IDE.  I use it because my colleagues (C programmers, mainly.) use it, and we use it for documentation too.  Is quite a versatile tool.  Best: it is free.
graziano
(3,722 Views)
An important point to remember is taht you need to configure LV properly for it to work well with and SCC system. You need to set two configuration settings:
  1. Treat read-only files as locked
  2. Don't save automatic changes
Remember to set those and everything will work fine.
Mike...
PS: Despite the whineing you might encounter on another thread, I have used Subversion (also known as SVN) for years and wouldn't be without it. I works great.
Certified LabVIEW Architect
LabVIEW Champion
(3,696 Views)
H Jimmy,
I hope that this thread will give you some useful ideas & suggestions.
- Partha ( CLD until Oct 2027 🙂 )
(3,687 Views)
Since LabVIEW source is binary, it is virtually impossible to merge using a source code control system (newer versions of LabVIEW have a merge VI facility to help this).  This problem means you should modularize your development as much as possible to avoid having multiple people working on the same VI.
A convention we have used that may help.  If someone needs to check out a VI so they can save it with a few breakpoints for debugging, they do not lock it and simply revert it when finished.  If someone needs to check out a VI to edit it, they lock it.
Good luck!  Let us know if you run into problems.
(3,664 Views)
Hi!
   Actually, I've never merged, since I'm the only LabView guy on our development team Smiley Happy
   I absolutely agree with the fact that SVN is a good tool, but I should confess that I didn't spend much time in evaluating many other tools (never tried MS tools), for this I rely on my colleagues' opinion.
   I can report that SVN is being used in a graphic studio for pictures versioning Smiley Happy of course, they don't need to merge images Smiley Very Happy  There's virtually no limit in SVN use...
graziano
(3,651 Views)
