Project file becomming corrupt
Hoping to find some help with this...
I am working on a larger project that was originally written in 2009(??) (whenever shared variables were introduced) The project has been converted to 2013 and has worked (for the most part). However I recently had to make a change that is causing the lvproj file to become corrupt. There is a large cluster of information that I needed to modify to contain a class object. Everytime I do this, I get no errors and the program seems to run, but when I try to open the project the next time LabVIEW tells me the project file is corrupt.
Other maybe relevant information:
OS is Windows XP 32bit
LV 2013
The cluster used to feed into a shard variable, but I changed it to a Global variable becuase shared variables don't accept Class data.
The class is coming from a vip, not the project itself.
Any insight into why this would corrupt the lvproj???
I may not be able to respond right away, but will check this in the morning.
(2,744 Views)
Can you upload an image or something
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,721 Views)
Sure, the first image is the unmodified cluster. This code doesn't cause any issues. The reference that I need to replace is highlighted in red. When I change that to an object (shown in the second picture) I don't get any error and the program seems to run ok, but the project file becomes corrupt and I can't open it again.
I am trying to verify that this isn't an issue with my computer and loading labview on another computer right now. I will follow up if I am sitll having issues.
(2,700 Views)
I have now confirmed that is error is not specific to one computer. I can work around this, and luckily I have a backup from a few days ago, but this could be a huge problem if it wasn't backed up.
(2,682 Views)
I think I have found the problem.
It seems another VI was still trying to plug the cluster into a shared variable. I don't know why LabVIEW didn't give an error, but that seems to violated some basic rule (having a Class Object in a Shared variable) which caused the project file to become corrupt.
(2,671 Views)
