Programming without hardware-property node
Eh. Bit more than 5 minutes but here's the scripting code I came up with.
Some key points are described in Wiebe's post here:  LabvVIEW Scripting: wiring a pass-through tunnel inside a case structure
The code is saved in 2019.
GCentralI'm attending the GLA Summit!
Message 11 of 12
(500 Views)
Thank you so much chutcher for your great help. I am looking at your files, those notes are really helpful. Thanks again. I will work on it and give an update here.
Message 12 of 12
(484 Views)
