Programming multiple NI-9402 Channels Using cDAQ-9178, need help
i need to program 13 channels with a vector file and have it loop over and over.
Im using a cDAQ-9178 with 4 NI-9402 modules in it.
Labview v20 and NI Max v20
The program will work as long as i only write to 4 channels on the same module and cut my vector pattern down to just 4 channels.
But if i select 2 channels from 2 different modules it want work.
I have not read anything that says i can't control multiple NI-9402 at the same time.
I need some help.
thanks,
les
(2,118 Views)
here are the programming files that did get attach before.
les
(2,098 Views)
Could you please post the code in LV 2016 version, you will cover a broader audience by doing that.
Santhosh
Soliton Technologies
(2,085 Views)
Here is the VI saved in 2016 LV
(2,052 Views)
Hi les,
When it "don't work" which error do you get?
You get an error, don't you?
(2,039 Views)
