Programming lags with classes
Hello
I am having real troubles with programming lags in LabVIEW while working with LabVIEW class libraries. I hope to get some hints on what to do against it.
I started using LabVIEW classes extensivly with inheritance and dynamic dispatching. I noticed that on projects I use these, I am getting slow response while programming the block diagrams. After every action I see the Windows circle for 1-2 seconds. This is more than annoying..
I have the same behavior in LabVIEW 2010 to 2013. My development system is a Win7 64bit i/ with 8 Gb RAM.
I have seen more posts on that issue but none with a real solution. Maybe there is some new knowledge around..
Kind regards
Message 1 of 16
(4,456 Views)
Hello
I'd like to help you to find a solution for these annoying lags.
To find out, what caused the slow edit response time, I would like to have more information about these projects using the class libraries:
1. Refering to your text, you get these lags in projects with classes, thus there are no lags in projects without classes, are there?
2. Do you open the projects from a local machine or from a network?
3. How is the CPU usage when you are editing code with these lags?
4. Which size has your project?
5. How is the hierarchy of your project looks like?
                    -> How many LV classes do you use?
                    -> Which is the total number of VI call paths in VI hierachy (recursive code paths?) ?
Best regards,
Janina
Message 2 of 16
(4,399 Views)
Hello Janina,
thank you very much for your reply.
I hope I can provide the information to find the cause. But I think it will be hard, because I see this only in medium to big projects and the those projects are a mix of different components. So it is hard to find the real cause digging into the projects. Also  the lags increase with development time on one project. So when I start LabVIEW, the development is ok. But after a while of development the lags get so long, that I have to shut down LabVIEW and reopen the project. I think this correlates with opened VIs or methods.
I reduced the count of undo steps and tried the setting for the compiler complexity. It didn't really help. Also I do frequently Mass Compiles.
The lags come after every single action in the block diagram. For example: Placing a VI - Windows Circle - Moving the mouse over the connector - Windows Circle - Connecting a wire - Windows Circle - Moving the wire in the block diagram - Windows Circle - etc..
I think I saw it only in project with classes. The classes use mainly the data access via property nodes option. Also I use Singleton pattern with DVR
Only local machine.
You can see peaks in the system monitor, which correlate to the lags I guess. I attached a screenshot.
I ran VI metrics and saved the data. See attached file. Can I run other analysing tools? I have a standard developer suite.
I think the VI Metrics of the main VI is not complete, because some VIs are called by reference and loaded into subpanels.
I dont really know how to collect this information. The VI hierachy is not really usable, because it is a big project.
But most is structured into lvlibs or lvclasses.
Maybe you have some general information on how to reduce LabVIEW lagging.
Message 3 of 16
(4,370 Views)
Sorry,
I just noticed that the SystemUsage Screenshot is not representative. Yesterday I tried som other RAM settings, which now reduced the available RAM. I resetted those settings and attached a screenshot of system state after reboot.
I will try to capture another system usage screenshot at development tomorrow.
Message 4 of 16
(4,360 Views)
I took some new system usage screenshots. #2 is taken at class data editing. #3 is taken when creating data access vis with the LabVIEW dialog. All in LabVIEW 2013.
Message 5 of 16
(4,339 Views)
I added a screenshot of the class inheritance dialog. This gives a feel for th enumber of classes used.
Message 6 of 16
(4,332 Views)
Try using the .lvclasses freely instead of in a project and compare how it feels.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 16
(4,307 Views)
Thank you for the detailed information.
I had a look at the files and would like to see your code now, because referring to your .txt-file, there could be a problem with some code fragment.
You said that you have a similiar problem with other projects with classes, so you also could show me a smaller project file instead of this one, if this one is too large.
Kind regards,
Janina
Message 8 of 16
(4,293 Views)
Hello Janina,
sorry, but I cannot give out the whole projects.
Can you point me to where the problems might be. I will see if I can send parts of the code.
The different class libraries are reused in different projects.
Regards
Message 9 of 16
(4,277 Views)
Hello Yamaeda,
sorry, but I couldn't work without the project.
Message 10 of 16
(4,274 Views)
