Programming Ultrasonic sensor HC-SR04
Hi Gerd,
I am using the PFI0  for trigger and I am designing a counter. ( I am using a digital input (of usb6008) (echo pin connected to it) and reading the boolean value. For each true, the counter is incremented.
I've attached my counter part
Message 11 of 22
(2,033 Views)
Here is my vi
What's wrong?
Please help!
Message 12 of 22
(2,015 Views)
Hi kdm,
I don't know what's wrong. You don't tell us, what's not working as expected…
- You read your DI once each 14ms (due to AI task set to 1000S/s and 14 Samples/read).
- You increment your counter on each edge of the digital input - that's different to your text "increment on TRUE".
- You do a lot of stuff more complicated then needed to…
Message 13 of 22
(2,008 Views)
Hi Gerd,
What does this error mean..
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Change Detection
You Can Select: On Demand
No, I think I read my samples for every 140us  (due to AI task set to 100000S/s and 14 Samples/read). ..as minimum width of the pulse of echo is 150us.
Message 14 of 22
(2,004 Views)
Hi kdm,
the USB6008 is NOT ABLE to read a AI with 1MS/s. AGAIN: read the specs of the USB6008!
You alse mis-wired your settings: You did wire a 1000 to rate input of DAQmxTiming and a 100,000 to sample size input. Please read the context help for that function…
That error message is quite clear: you wired a property setting that is not supported by your hardware!
Conclusion: READ THE SPECS!
Message 15 of 22
(1,993 Views)
Hi Gerd,
Okay
I think my trigger is not generating 10us. How to check that?
Message 16 of 22
(1,989 Views)
For a 10us trigger, what should the high time and low time be?
Message 17 of 22
(1,972 Views)
Hi kdm,
you can check your outputs using a scope…
AGAIN: Read the specs of the USB6008. It is not able to prduce 10µs pulses!
Message 18 of 22
(1,966 Views)
Hi Gerd,
The specs says that the minimum input pulse width is 100ns. I could not find any details about the minimum __output__ pulse width.
Message 19 of 22
(1,956 Views)
You aren't making any sense. There is a spec for the trigger input to the basic event counter. There is no such thing as a trigger output. The only output you have is the digital I/O and that is software timed. The minimum pulse it's going be in milliseconds with considerable jitter. You've been told numerous times that the device is not capable of generating a 10us pulse.
Message 20 of 22
(1,952 Views)
