Programmatically update nested Arrays of Clusters? (Is this the Best Way?)
I have a array of configuration files that gets loaded at startup. Then I need to update values within this array of configuration values. The attached VI works but I was wondering if this is the best way. It doesn't seem scaleable as I added Items I need to update (Especially because the true configuration file has a lot more items).
Is this the best way to update an item in nested arrays of clusters?
In this shortened version:
When I click "Set New Value" it should set the updated values for the selected Config #, Test #, SubTest #.
Backpanel:
Thanks!
(3,191 Views)
Accepted by topic author kjschill
A much better approach is to use the standard bundle/unbundle and index array/replace array subset pattern. Using an Inplace Element Structure simplifies this, as shown:
(3,178 Views)
nathand,
I had never heard of/used In Place Element Structure Before. Definetely easier than the method I was using.
If you saved the vi could you post it back up so everyone has a good reference to your solution?
Thanks a Ton!
(3,170 Views)
The image I posted is a "snippet" - it's actual LabVIEW code. You can drag it into a block diagram (or, in some web browsers, drag it to your desktop, then from there into a block diagram). That said, you should not use the code I posted directly, because it does not link to all your type definitions (some of which were missing from your ZIP archive).
You don't have to use an In Place Element - it works just as well to use unbundle/bundle and index array/replace array subset. In Place Element just makes that simpler
(3,168 Views)
