Programmatically trigger a latch boolean?
Hi rajiv,
I will need to find out what is the difference between: notifier status and wait on notification.
NotifierStatus gives the current notifier value without waiting for a new notification.
WaitOnNotification does wait for a new notification (or til timeout)…
Message 11 of 13
(873 Views)
Uhmm in this case, this is also what I understood but it is not logical to me why it would not be needed for multiple notifications :S But anyway it is for another topic. Big thanks for the help Smiley Very Happy
Message 12 of 13
(871 Views)
I do this all the time (if I understand you correctly). I just set the boolean's Mechanical Action to Switch mode. Then I can use a "Value (Signaling)" property node to trigger the "Value Change" event on the boolean. Within the Value Change event, I use a Local Variable or Property Node to set the value of the Boolean back to false.
This way, the boolean acts very much like a latch.
Message 13 of 13
(850 Views)
