Programmatically set datasocket url
I apologize if I've posted this message here before.
I am trying to write a 'template' VI that can configure its DataSocket connections once the VI is run. This would allow me to create one VI that can be run multiple times (reentrant) to connect to several identical devices. The documentation indicates that this property is settable at runtime, but it never works and I get a 'Invalid Status' indication from the property DataSocket:Status.
Please advise me on how to make this work.
Thank you,
Peter Laskey
peter.laskey@jdsu.com
(3,329 Views)
Peter,
I think you might have to prime the pump a little bit by configuring the relevant front panel controls on your VI to expect a DataSocket connection before you actually run the VI and assign the connection(s).
For instance, if you've got a graph that you want to use to display data, right-click on the graph, select Data Operations >> DataSocket Connection..., give it some arbitrary URL (I used dstp://localhost/placeholder) that doesn't correspond to any source that you actually plan to use, and save your VI this way. As long as you've done this, it seems that the DataSocket properties are writable at run-time for the control; otherwise, I get a 1087 error ("There is no DataSocket information available for the object.") and the Invalid Status code you described.
It's surprising that there isn't more material about this either on the NI Web site or in the documentation, and it makes me suspect that perhaps we're both still missing something. However, maybe most people are using the full-blown DataSocket open/read/write VIs to manage programmatic DataSocket applications and don't run into this problem as a result.
John
(3,303 Views)
