Programmatically select/deselect Excel COM Add-Ins
Is it possible to programmatically select/deselect Excel COM Add-Ins using Active X?  Thanks in advance.
(4,196 Views)
Hi AT1,
I don´t know how familiar are you with LabVIEW, but there are some examples that you can follow similar to what you are trying to do. If you go to help and you search for activex then you will see some examples.
If that property or method in particular is available, I believe the best approach you can take is to verify with microsoft since they are the owners of Activex.
(4,114 Views)
Accepted by topic author AT1
I found that setting the EnableEvents property node method to False worked for me.
(4,067 Views)
