Programmatically reading controls in a Tab Control
I can use Property Nodes to read controls on a front panel, but they seem to miss controls inside a Tab Control.
Is it possible to programmatically read controls in a Tab Control?
Attached is an example VI illustrating this.
(3,097 Views)
I didn't open your code.
A tab control has a property called Pages. This is an array of page references. Wire this property node to a for loop, then use a property node to read the property CtlsOnPage to get an array of references for each element on the page of that tab.
(3,076 Views)
That works, thanks.
(3,064 Views)
