Programmatically paste an image from Clipboard into LabVIEW picture control
Does anyone know of a way to programmatically paste the image residing in the Windows Clipboard into a LabVIEW picture control?
Jim Haas
(6,072 Views)
Accepted by topic author JHaas
There's an Application class method which gets the image from the clipboard. It was private in previous versions, but it was made public in 2012, so I assume it also works fine in older versions. At least in never gave me problems with my limited experience with it:
___________________
Try to take over the world!
(6,059 Views)
It works!!! Thanks much and congrats for being knighted into 10k club
Jim Haas
(6,024 Views)
Hi!
Great post!  I'm wondering where I can find this. I checked the Application methods > Clipboard option which provides a text read and text write option. Your help would be appreciated. I'm using Labview 2011. Thanks!
(5,953 Views)
Like I said, that method was private, which is why you can't see it. If you want to use it, save the image in my previous reply to your HD, then drag the file into a block diagram. It's a VI snippet, so it will be converted into actual code you can use. You could also drag it directly from the browser, but I believe that only works if you're using Internet Explorer.
___________________
(5,929 Views)
Thanks! This is new to me, so thanks for the information. It works well, in both IE and Firefox, too.
(5,913 Views)
