Dear Brian,
There is a toolkit called Database Connectivity Toolkit that allows you to read from a database in LabVIEW. You could then use DAQmx Create Scale.vi to create a scale based off of your database values and DAQmx Save Scale.vi to save it to MAX. In MAX, just open a Custom Voltage with Excitation and select your scale as the custom scaling.
In MAX, accelerometers are assumed to be IEPE accelerometers, which are excited by currents and not voltages. Since the SCXI-1520 provides voltage excitation, it will not show up in the list. This is exactly why we have Custom Voltage with Excitation tasks.
If at any time you would like to make a product suggestion, you can do so at the Product Feedback link. Have a great day!
Sincerely,
Marni S.
Thanks, currently we are going to be ordering the database toolkit in the very near future but for now I've been using a freeware database toolkit which is quite handy. It's only limited in documentation. It can be found here if you want to check it out. http://www.jeffreytravis.com/lost/labsql.html
Maybe you and others already know about this. It works pretty well. Still I would like to see what NI Database Toolkit actually is capable of doing.
Brian
