Programmatically control relational DB properties DSC
New in 2010 are the Relational DB properties for logging in the DSC module.  Are these feature exposed to allow programmatic deployment and modification?  I know they are not available in the Distributed System Manager and I have only seen this capability through the project explorer.
(2,985 Views)
Beardsell:
If you're referring to the 3rd party relational database settings, then the library settings dialog is the only place those can currently be set. That would, however, be a good item to put in the product suggestion center. Robot wink
Caleb Harris
National Instruments | http://www.ni.com/support
(2,962 Views)
You are correct and I will do.  Thanks for your help.
(2,935 Views)
