Programmatically changing text color on Items for multi-column listbox.
I wasn't able to find a property to be able to programatically change the text color for Items on a Multi-column listbox. Does anybody know of a way to do this programatically? I am doing this manually and it takes quite a while to do on larger arrays.
If you know how please respond if you can.
Thank you,
Atwork
(3,041 Views)
The property is called "Cell Foreground Color" it applies to whatever is specified in the "Active Cell" property. If you specify cell number (-2,-2) then all cells are active. A (-2,0) would be all rows, first column. I believe that you use -1 to specify the headers.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(3,041 Views)
This did the trick. Thank you so much.
Atwork.
(3,041 Views)
