Programmatically changing chart stacking in subvi from compiled application.
I am creating a data aqusition application which needs to display a variable number of waveforms (1-16). I have a main vi that uses vi scripting to configure a Waveform Chart contol owned by a dynamic subvi. I would like to be able to deploy this as a compiled application vi, but when I create the application I get the following error:
Error 1073 occurred at Property Node (arg 1) in Daq.vi
Possible reason(s):
LabVIEW:  This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
Does anybody know a work around for this issue? Attached is a screen capture of the relavent code.
Kevin
(2,773 Views)
See the detailed help on Stack Plots property. It is read only in runtime.
(2,742 Views)
PiDi, this is a duplicate post, and has already been answered
(2,734 Views)
Oh, the dangers of looking at unanswered questions on forum 😜
(2,725 Views)
