Programmatically change selected cell/row of multicolumn listbox
@MGiacomet wrote:
>>Your MCLB datatype is defined as a scalar (selection mode 0 or 1 item or 1 item
Ok, my bad in the pic; but the (wrong) behavior is the same even if set for multiple selection
Seems fine here. See attached. As I said, you still have to decide which row you start from.
>>Your MCLB doesn't have the key focus
Setting Key Focus puts an extra border around the MCLB, which isn't shown (or needed) once you do a mouse click to start the selection
Fair enough. I don't particularly like the look of the border either, but as I said, I don't think I ever needed this.
___________________
Try to take over the world!
Message 11 of 17
(1,698 Views)
And it looks like there are some workarounds for the key focus border:
https://forums.ni.com/t5/LabVIEW/How-do-I-get-rid-of-the-Key-Focus-object-border/m-p/844469#M383119
https://forums.ni.com/t5/LabVIEW/how-to-remove-String-key-focus-border/m-p/4054018#M1162990
___________________
Message 12 of 17
(1,692 Views)
Keeping "Focus" (pun intended), here...
There isn't really a way to programmatically start the selection (confirmed by NI's support); The MCLB needs a mouse click (you'll only see the dotted border around the selected item, thus indicating the selection starting point, if a mouse click happens) to start the selection.
Message 13 of 17
(1,667 Views)
Fair enough. I personally don't like the highlighting of a single cell and set the MCLB to highlight the entire row, so I don't mind, but it is true that even though it does provide the requested functionality, it doesn't behave in the exact same way as clicking it with the mouse does.
I think that if I had a user who wanted it to behave in exactly the same way as happens when you click, then I would work around this by simulating a mouse click on the relevant cell.
___________________
Message 14 of 17
(1,659 Views)
Yeah, tried that... but if the user moves the mouse, the simulated click may happen at the wrong row/cell. Haven't found a way to temporarily disable the mouse to prevent this.
Clearly a bug (oops, NI will say "by design" 😜) that should have had a fix already.
Message 15 of 17
(1,651 Views)
image.pngHi,
I am facing this exact issue. I have 2 MCLBs, which are somehow connected, in which, if a row of the first one is clicked, specific items in the second Box must appear. I can use Porperty Node to highlight a row in the first MCLB, but this does not simulate the actual click, which must lead to showing the selection in the second table. Is there any news on this issue? image.png
Seli6272@D
Message 16 of 17
(1,213 Views)
Hi, I had the same issue !
use the pn FocusRow instead of SelectedCell
Message 17 of 17
(274 Views)
