Programmatically change mouse cursor size
LV 8.5 on Windows XP
Is there a way to change the size of the mouse cursor (custom or otherwise) programmatically? I can load custom cursors using included vi's but can't find a way to change the size - the cursor vi's are locked so I don't know what is going on behind them.
(5,885 Views)
Hi Jolt,
one solution could be to create your own big cursor and load it with the shipped vi´s.
Hope it helps.
Mike
(5,882 Views)
Another alternative if you are running on Windows is to use the API, as explained here.
(5,873 Views)
MikeS - thanks for the reply,
the problem here is that i don't just need a larger icon, i need to scale it based on user input (think of an inspection application). I could make a bunch but that seems combersome.
Message Edited by Jolt on 07-10-2008 06:17 AM
(5,848 Views)
smercurio,
I had found that thread but the API example is written in 5.1, unfortunately I have wiped this machine several times since running 7.1 and would rather not reinstall if I can avoid it. (As I understand it 7.X can open the 5.X and THEN I can open in 8.X)
I will look around for a machine running 7 and go from there but any other suggestions would be appreciated.
Thanks again!
-Jolt
(5,845 Views)
I found a 7.1, converted the demo, and opened in 8.5 - this works well! thanks!
-Jolt
(5,833 Views)
