Programmatically Set Page Setup when printing with Internet Explorer?
I'm using the LabVIEW 7.1 Print HTML Report VIs.
However, I'd like to change the default margings and footer and headres of Microsoft internet explorer which is used to do the actual printing.
I tried to find a way using the functionality of IWebBrowser2 (Wich is actaully used by the original VIs). It seems I have to use OLECMDID_GETPRINTTEMPLATE and pass a structure of the type ITemplatePrinter.
How can this be done - or is there a more simple way to do this?
Thanx,
Rainer
(15,089 Views)
Good question. I'm using IE's print preview feature for our HTML reporting and it's great but there's a way to send a template htm file to printpreview and print by specifying a flattened string variant to pvaIn of ExecWB. I didn't get this to work. Did anyone else?
(14,905 Views)
I'm looking for the same features.  Ideally you would be able to send the page setup parameters to IE programatically but so far I've had no luck doing that or finding any reference on how it would be done.  The closest thing I've seen is the print templates, but I am still unsure how those would be implemented exactly.  I did find this reference for the template which seems fairly descriptive:
http://msdn2.microsoft.com/en-us/library/bb250434.aspx
Message Edited by Deej60 on 04-03-2007 06:17 PM
(14,865 Views)
have you tried the registry?
(14,848 Views)
You mean to edit the Page Setup default values registry settings for IE ?  I thought about that but didn't try it yet.
(14,841 Views)
Jackpot!
http://support.microsoft.com/kb/236777
Thanks for the tip.  Had you already found that article?
(14,834 Views)
No. However i knew this should be possible. (MS does love hidden registry settings). So i had to kinda dig around the registry myself (painful). But that's a great article, that'll allow me to show it to my boss so as to convince him that even the big brother does it and it is safe. Thanks!
(14,813 Views)
