Programatically determine the used log file path for a source distribution
Is there a way to programmatically determine the log file path entered inth the "Generated buld log file" option of a source distribution?
(3,029 Views)
Hi xl600,
read the project file (*.lvproj) using a text editor - it's just a XML file.
Search for your source distriution entry and check its log file path…
(3,026 Views)
Looks like there's a "Bld_userLogFile" property that holds a relative path from the project file path.
I also found a Get User Log Path.vi under
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\AppBuilder\AB_API\Build
Which is probably doing the same thing (Reading the project).
Thanks for the clue!
XL600
(3,011 Views)
