Programatically detecting a wave from a noisy Wave.
Dear folks,
I have a wave which i have acquired and need to figure out by means of a code what kind of wave is it. Is it a sine wave, Square Wave, Triangular wave... I did make a small program which takes the fft of the acquired wave and deconvolutes it against the fft of a standerd wave. This works fine with a pure wave and is very predictable. I then tried using the same with a realworld signal, but the noise in the wave upsetted all the value ranges. Can someone sugggest a better meathod??
Ankur
(3,250 Views)
you can find some suggestion in "lvmeas.pdf" in the labview manual directory: anyway you should filter the signal before doing the spectral analysis on it.
regards
CLD - Labview Certified Developer
(3,241 Views)
Ankur,
If you have only a small number of standard waveforms and they all have well-behaved mathematical descriptions, try curve-fitting the standard function to the (noisy) data and then extracting the parameters from the fitted curve.
Lynn
(3,232 Views)
antea06,
Tried that. the problem is that incase my acquired wave is essentially a square wave, the edge is distorted on filltering  and the fft of the data after deconvolution is then very close to a sine wave. So i tried the commmunities. I tried digitizing the wave and removing the lsb values of the wave. It resulted in the sine and triangular wave having very simmilar charecteristics. Thaught i could use a lock in amplifier to extract the vave, but all it gives us is a single point value in intensity of the reference wave.
Thanking You
Ankur Kumar
(3,230 Views)
Have you already tried to averaging the signal on multiple acquisitions ?
(3,225 Views)
I mean, in your vi (subvi Power Spectrum) what happens if you enable the averaging?
(3,223 Views)
