Programatically change possible selections in radio buttons
I'm making a dialog box asking the user to select one of multiple strings from an array, so I'm using radio buttons for this. Is there a way to make the possible selections of a radio lab with a property node? I was not able to locate a way to do this.
Message 1 of 11
(4,531 Views)
Why wouldn't you use a MENU RING instead of the radio buttons for a selection from an array of strings?  The property node of a menu ring allows for on the fly (run-time) changes to the selection options?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 2 of 11
(4,525 Views)
That was my backup plan. I was hoping to have a nice table showing all their options without a drop-down menu like with a menu ring. I was trying to modify a table with checkboxes to have radio buttons instead since I already have the dialog window built.
Message 3 of 11
(4,522 Views)
Hi Quark,
use a listbox to show all possible entries. Set it to allow selecting just one item...
Message 4 of 11
(4,514 Views)
According to the LabVIEW Help for Radio Button Properties, this is a Read-Only property, so the answer is No.
Message 5 of 11
(4,505 Views)
Like GerdW, I would go with the Listbox set for selecting a single item.
Message 6 of 11
(4,469 Views)
You can simulate this, I guess, by making an array of cluster, where the cluster would be a Boolean control + a string control.
Bill
CLD
(Mid-Level minion.)
Message 7 of 11
(4,463 Views)
Then use a listbox and their inbuilt feature to show symbols in front of the list items…
Message 8 of 11
(4,454 Views)
This sounds like it could be a fun XControl using a 2D Picture control, or a listbox with custom symbols.  A while ago I posted code on custom symbols in item selection for listboxes that allow for multiple item select.  Feel free to modify the code to use radio button symbols instead.
Message 9 of 11
(4,431 Views)
I just use (hidden) sequential labels, and change captions programmatically instead
Message 10 of 11
(4,424 Views)
