Programatically Connect to Oscilloscope via IP
So I have a program that connects to a VISA resource that has been setup in the MAX tool before. However, the IP address of my oscilloscope isn't static, so I have to change the VISA resource settings every few weeks. Is there a way to pass in an IP address as a parameter to the program and automatically create a VISA resource.
(2,915 Views)
I would set up a static IP address on the scope.
(2,901 Views)
If a static IP address isn't an option, is there any other way to do it?
(2,897 Views)
You can wire a string to VISA functions in place of a VISA resource. You can edit the string so it contains the correct IP address.
EDIT: Or you can skip VISA entirely and use LabVIEW's TCP/IP functions.
(2,893 Views)
Thanks! I will go with the first option, could you please elaborate? Can i just pass a string saying "123.123.123.12" or whatever into the "Visa Resource Name" input, or is there more to it than that?
(2,885 Views)
It needs to look exactly like the text in the VISA resource. Wherever the IP address is within the resource, replace that and keep the rest of the text the same.
(2,883 Views)
