Programatic access of [CommonAppDataFolder] and other system set folders
I have found how to access the default data directory (labview specific), but how can I access the system specific directories that are available in the 8.5 installer in my source code?  I've searched upon this and can't find the answer.  On example of such a directory is CommonAppDataFolder where configuration files can be stored to share between users.
Michael Wise
(2,862 Views)
See this post.
It is not yet achievable, but considered for future versions (read LV 9 or 10).
Otherwise you need the sys32.dll
Ton
My LabVIEW Ideas
(2,849 Views)
If you want to use existing code, you can search the LAVA forums for "system folders" or something else along those lines, since there were some VIs posted there to do this.
___________________
Try to take over the world!
(2,832 Views)
