Program using activex works only one time
Sure, I uploaded both. Thanks for the help.
Message 11 of 14
(554 Views)
Which .vb file does the code in question reside in? I don't have VB.Net installed or I'd search the entire project...
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 12 of 14
(550 Views)
I don't know exactly where that part of the code is, but my coworker told me this:
The port open/close is handled internally by the DLL.  By releasing the object (in VB this is done by setting the object to nothing). In VB all references to the object are removed by setting the object = nothing.
Message 13 of 14
(548 Views)
Did you try running the VB code which only contains open and close? Here we need to compare 2 equivalent codes.
TailOfGon
Certified LabVIEW Architect 2013
Message 14 of 14
(536 Views)
