Program only writes one line into the csv file?
For some reason the program only writes one line despite the code executing multiple times?
(3,030 Views)
Accepted by topic author crash_override
Yes.  Because you keep reopening the file within the loop which will cause it to reset the file pointer to the beginning.  It may also cause a memory leak of open file references you never close.
Put the File Open before the while loop.  Add File Close after the while loop.
Also, clean up your block diagram using the Block Diagram Cleanup button on the toolbar.
(3,018 Views)
I did not know about that cleanup function. That is amazing, thank you very much.
(2,932 Views)
(2,914 Views)
