Program event Sounds - Windows
Is there a stright-forward method of generating Windows Program event
sounds from Labview (6.0.2) ?
Aside:
In 2000/XP "Control Pannel - > Audio -> Sounds" You can choose and
customise the desktop sound scheme and attach different wav soudns to
different types of program events.
"Well behaved" windows Apps use these defined sounds/events instead of
generating their own custom sound for consistancy. So how do I make
"well behaved" sounds from Labview?
many thanks,
Peter
(2,845 Views)
Hi Peter,
You'll want to use the "PlaySoundA" function found in the windows DLL "winmm.dll." I found the information I needed from this website:
http://www.dotnet247.com/247reference/msgs/20/104009.aspx
I created and attached a VI that will play the "MailBeep" event.
I hope this is useful for you! Good luck,
(2,845 Views)
