Program chip registers with labview
Hello. I am trying to program chip with labview using file with register data but I have no idea how to do it . What I’m doing now is manually write, with write function, address register and data . If I Jeff to change something I need to change each register . How this can be done so the data for the registers are read from file ? I don’t have any VI to share. Thanks
(1,021 Views)
Which chip and what register? how do you connect your chip to the computer that runs LabVIEW?
Santhosh
Soliton Technologies
(1,007 Views)
Hello, Natasha.
Please attach some LabVIEW code that you have developed related to this question.  Be sure to mention the hardware that you plan to use (and that is used in the code example).  In order to provide any reasonable help, we need to better understand (a) what you are trying to do, (b) what hardware you are using to access "chip registers", (c) what "chips" you are using, and (d) some examples of the LabVIEW code that you have written to do this.  This last item is especially important as it can indicate to us the level of understanding and experience you have with LabVIEW, which allows us to provide the most appropriate level of help.
(933 Views)
