Program LabVIEW to connect with webrelay
I am using Labview 2011 and trying to establish communication with webrelay (X-WR-4R1-l) to control its relays.
I have downloaded an example from (http://www.controlbyweb.com/webrelay-quad/downloads.html#code) but it does not work.  (it has been attached with this thread as well)
And reverse engineering the program did not workout well as the it is quite complex for an example program.
I planning to control the relays individually, meaning to say:
in labview runtime, when button 1 is pressed, it should activate relay 1 of the webrelay.
  -  button 1 = activate relay 1
  -  button 2 = activate relay 2
  -  button 3 = activate relay 3
  -  button 4 = activate relay 4
is it possible to achieve this function on labview?
is there and examples available to create this function?
and the hardware connections are fine as i am able to control the relays individually through web based setup which can be found in the manual i attached with this thread.
i did also attach the example program that i found on the web, and also the manual.
thank you
(3,194 Views)
(3,179 Views)
