Progmatically read CompactRIO 90x controller voltage
I am creating a DAQ system for a vehicle using a cRIO-9012 and 4-slot FPGA chassis.  Is there a way to progmatically read the supply voltage of the embedded controller?
(2,792 Views)
There is no direct way to read the voltage supplied to the embedded controller. (The controller does not include a ADC inside the power supply.) The simplest alternative would be to include a cRIO-9221 analog input module in your system and route the controller supply voltage to one of the analog inputs to measure the voltage.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,784 Views)
