Progarmmatically change Mixed Signal Plot Names
I have two plot areas on my mixed signal graph. I want to programmatically update the plot names of the seconf Plot area in the mIxed signal graph. But I am unable to do so. I have set property as Active Plot Area as 1 and then Active Plot as shown in the document attached. If I put Active plot area as zero or one, only the plot names in the first graph changes not the second one. Please let me know how to do this.
(2,555 Views)
There is a little confusion. As far as i understand your need, you want to modify Scale Name, you do NOT want to modify Plot Name in the second area.
As you can see below, my LabVIEW is in french...So there is a little text beside property node to translate properties and help you finding the relevant properties in english :
(2,547 Views)
Hello
Thanks for your reply. . I am able to change the Y scale name. No problem. But I want to change the plot names programmatically. Like in your example, plot name shows as Trace 0, Trace 1 and Trace 2. Similarly, I want the plot names to be changed in the program in the second Active Plot area of the mixed signal graph.
Thank you
(2,525 Views)
